Computational Infrastructure of SoilGrids 2.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
SoilGrids maps soil properties for the entire globe at medium spatial resolution (250 m cell side) using state-of-the-art machine learning methods. The expanding pool of input data and the increasing computational demands of predictive models required a prediction framework that could deal with large data. This article describes the mechanisms set in place for a geo-spatially parallelised prediction system for soil properties. The features provided by GRASS GIS – mapset and region – are used to limit predictions to a specific geographic area, enabling parallelisation. The Slurm job scheduler is used to deploy predictions in a high-performance computing cluster. The framework presented can be seamlessly applied to most other geo-spatial process requiring parallelisation. This framework can also be employed with a different job scheduler, GRASS GIS being the main requirement and engine.
493342_1_En_3_Chapter.pdf (329.43 Ko) Télécharger le fichier
hal-03361904 , version 1 (01-10-2021)
Paternité
Luís Sousa, Laura Poggio, Gwen Dawes, Bas Kempen, Rik van Den Bosch. Computational Infrastructure of SoilGrids 2.0. 13th International Symposium on Environmental Software Systems (ISESS), Feb 2020, Wageningen, Netherlands. pp.24-31, ⟨10.1007/978-3-030-39815-6_3⟩. ⟨hal-03361904⟩
46 Consultations
62 Téléchargements
