New interface
Journal articles
Optimal Prefetching in Random Trees
Kausthub Keshava 1 Alain Jean-Marie 2, * Sara Alouf 2, 3
* Corresponding author
2 NEO - Network Engineering and Operations
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : We propose and analyze a model for optimizing the prefetching of documents, in the situation where the connection between documents is discovered progressively. A random surfer moves along the edges of a random tree representing possible sequences of documents, which is known to a controller only up to depth d. A quantity k of documents can be prefetched between two movements. The question is to determine which nodes of the known tree should be prefetched so as to minimize the probability of the surfer moving to a node not prefetched. We analyzed the model with the tools of Markov decision process theory. We formally identified the optimal policy in several situations, and we identified it numerically in others.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03361953
Contributor : Sara Alouf Connect in order to contact the contributor
Submitted on : Friday, October 15, 2021 - 2:13:50 PM
Last modification on : Friday, November 4, 2022 - 3:02:51 PM
File
mathematics-09-02437-v4.pdf
Identifiers
Collections
Citation
Kausthub Keshava, Alain Jean-Marie, Sara Alouf. Optimal Prefetching in Random Trees. Mathematics , 2021, 9 (19), pp.2437. ⟨10.3390/math9192437⟩. ⟨hal-03361953v2⟩
Share
Metrics
Record views
55
Files downloads
69
