Identifiability in Exact Multilayer Sparse Matrix Factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Many well-known matrices Z are associated to fast transforms corresponding to factorizations of the form Z = X^(L). .. X^(1) , where each factor X^(l) is sparse. Based on general result for the case with two factors, established in a companion paper, we investigate essential uniqueness of such factorizations. We show some identifiability results for the sparse factorization into two factors of the discrete Fourier Transform, discrete cosine transform or discrete sine transform matrices of size N = 2^L , when enforcing N/2-sparsity by column on the left factor, and 2-sparsity by row on the right factor. We also show that the analysis with two factors can be extended to the multilayer case, based on a hierarchical factorization method. We prove that any matrix which is the product of L factors whose supports are exactly the so-called butterfly supports, admits a unique sparse factorization into L factors. This applies in particular to the Hadamard or the discrete Fourier transform matrix of size 2^L .
main.pdf (755.3 Ko) Télécharger le fichier
hal-03362626 , version 1 (01-10-2021)
hal-03362626 , version 2 (11-11-2021)
hal-03362626 , version 3 (15-02-2022)
hal-03362626 , version 4 (04-04-2022)
hal-03362626 , version 5 (02-08-2022)
hal-03362626 , version 6 (07-10-2022)
Léon Zheng, Rémi Gribonval, Elisa Riccietti. Identifiability in Exact Multilayer Sparse Matrix Factorization. 2021. ⟨hal-03362626v1⟩
441 Consultations
632 Téléchargements
