Securing Wireless Coprocessors from Attacks in the Internet of Things - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jason Staggs
  • Fonction : Auteur
Sujeet Shenoi
  • Fonction : Auteur
  • PersonId : 991346
Wireless communications coprocessors are a vital component of numerous Internet of Things and mobile devices. These subsystems enable devices to communicate directly with peers and supporting network infrastructures. Previous research has shown that wireless communications coprocessors lack fundamental security mechanisms to combat attacks originating from the air-interface and application processor (main CPU). To mitigate the risk of exploitation, methods are needed to retroactively add security mechanisms to communications coprocessors.This chapter focuses on securing a cellular baseband processor from attacks by hostile applications in the application processor. Such attacks often leverage attention (AT) commands to exploit vulnerabilities in baseband firmware. The attacks are mitigated by installing an AT command intrusion prevention system between the application processor and baseband processor interface.
491841_1_En_9_Chapter.pdf (468.36 Ko) Télécharger le fichier
hal-03364568 , version 1 (04-10-2021)
Paternité
Jason Staggs, Sujeet Shenoi. Securing Wireless Coprocessors from Attacks in the Internet of Things. 13th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2019, Arlington, VA, United States. pp.159-178, ⟨10.1007/978-3-030-34647-8_9⟩. ⟨hal-03364568⟩
44 Consultations
91 Téléchargements
