Uniformly accurate schemes for drift--oscillatory stochastic differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Numerical Mathematics Année : 2022
In this work, we adapt the micro-macro methodology to stochastic differential equations for the purpose of numerically solving oscillatory evolution equations. The models we consider are addressed in a wide spectrum of regimes where oscillations may be slow or fast. We show that through an ad-hoc transformation (the micro-macro decomposition), it is possible to retain the usual orders of convergence of Euler-Maruyama method, that is to say, uniform weak order one and uniform strong order one half.
paper_UA_SDE.pdf (539.43 Ko) Télécharger le fichier
hal-03371466 , version 1 (08-10-2021)
hal-03371466 , version 2 (16-03-2022)
hal-03371466 , version 3 (15-07-2022)
Ibrahim Almuslimani, Philippe Chartier, Mohammed Lemou, Florian Méhats. Uniformly accurate schemes for drift--oscillatory stochastic differential equations. Applied Numerical Mathematics, 2022, 468-482, pp.468-482. ⟨10.1016/j.apnum.2022.07.001⟩. ⟨hal-03371466v3⟩
181 Consultations
99 Téléchargements
