$\zeta$-functions and the topology of superlevel sets of stochastic processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We describe the topology of superlevel sets of (α-stable) Lévy processes X by introducing so-called stochastic ζ-functions, which are defined in terms of the widely used Pers pfunctional in the theory of persistence modules. The latter share many of the properties commonly attributed to ζ-functions in analytic number theory, among others, we show that for α-stable processes, these (tail) ζ-functions always admit a meromorphic extension to the entire complex plane with a single pole at α, of known residue and that the analytic properties of these ζ-functions are related to the asymptotic expansion of a dual variable, which counts the number of variations of X of size ≥ ε. Finally, using these results, we devise a new statistical parameter test using the topology of these superlevel sets.
paper4.1.pdf (694.23 Ko) Télécharger le fichier
hal-03372822 , version 1 (19-10-2021)
  • HAL Id : hal-03372822 , version 1
Daniel Perez. $\zeta$-functions and the topology of superlevel sets of stochastic processes. 2021. ⟨hal-03372822⟩
35 Consultations
67 Téléchargements
