Navigation In Urban Environments Amongst Pedestrians Using Multi-Objective Deep Reinforcement Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Urban autonomous driving in the presence of pedestrians as vulnerable road users is still a challenging and less examined research problem. This work formulates navigation in urban environments as a multi objective reinforcement learning problem. A deep learning variant of thresholded lexicographic Q-learning is presented for autonomous navigation amongst pedestrians. The multi objective DQN agent is trained on a custom urban environment developed in CARLA simulator. The proposed method is evaluated by comparing it with a single objective DQN variant on known and unknown environments. Evaluation results show that the proposed method outperforms the single objective DQN variant with respect to all aspects.
ITSC2021.pdf (256.86 Ko) Télécharger le fichier
ITSC2021.log (28.7 Ko) Télécharger le fichier
ITSC2021.synctex.gz (121.06 Ko) Télécharger le fichier
hal-03372856 , version 1 (11-10-2021)
Niranjan Deshpande, Dominique Vaufreydaz, Anne Spalanzani. Navigation In Urban Environments Amongst Pedestrians Using Multi-Objective Deep Reinforcement Learning. ITSC 2021 - 24th IEEE International Conference on Intelligent Transportation Systems, Sep 2021, Indianapolis, United States. pp.1-7, ⟨10.1109/ITSC48978.2021.9564601⟩. ⟨hal-03372856⟩
55 Consultations
186 Téléchargements
