Codabench: Flexible, Easy-to-Use and Reproducible Benchmarking for Everyone - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2021
Obtaining standardized crowdsourced benchmark of computational methods is a major issue in scientific communities. Dedicated frameworks enabling fair continuous benchmarking in a unified environment are yet to be developed. Here we introduce Codabench, an open-sourced, community-driven platform for benchmarking algorithms or software agents versus datasets or tasks. A public instance of Codabench is open to everyone, free of charge, and allows benchmark organizers to compare fairly submissions, under the same setting (software, hardware, data, algorithms), with custom protocols and data formats. Codabench has unique features facilitating the organization of benchmarks flexibly, easily and reproducibly. Firstly, it supports code submission and data submission for testing on dedicated compute workers, which can be supplied by the benchmark organizers. This makes the system scalable, at low cost for the platform providers. Secondly, Codabench benchmarks are created from self-contained "bundles", which are zip files containing a full description of the benchmark in a configuration file (following a well-defined schema), documentation pages, data, ingestion and scoring programs, making benchmarks reusable and portable. The Codabench documentation includes many examples of bundles that can serve as templates. Thirdly, Codabench uses dockers for each task's running environment to make results reproducible. Codabench has been used internally and externally with more than 10 applications during the past 6 months. As illustrative use cases, we introduce 4 diverse benchmarks covering Graph Machine Learning, Cancer Heterogeneity, Clinical Diagnosis and Reinforcement Learning.
Codabench.pdf (1.31 Mo) Télécharger le fichier
hal-03374222 , version 1 (12-10-2021)
hal-03374222 , version 2 (06-01-2022)
hal-03374222 , version 3 (25-02-2022)
hal-03374222 , version 4 (27-06-2022)
  • HAL Id : hal-03374222 , version 1
Zhen Xu, Huan Zhao, Wei-Wei Tu, Magali Richard, Sergio Escalera, et al.. Codabench: Flexible, Easy-to-Use and Reproducible Benchmarking for Everyone. 2021. ⟨hal-03374222v1⟩
1115 Consultations
289 Téléchargements
