Goal-Oriented Metric-Based Mesh Adaptive Tidal Farm Modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The modelling of a tidal array farm is an inherently multi-scale endeavour. It requires the simultaneous resolution of tidal processes across tens or hundreds of kilometres of coastal ocean (including estuaries, or even entire seas), the hydrodynamics in the neighbourhood of the farm (hundreds of metres), the wakes of individual turbines (metres, or tens of metres) and device hydrodynamics (sub-metre). As such, the construction of an accurate, computationally efficient numerical model requires careful consideration of the underlying discretisation.
hal-03374286 , version 1 (12-10-2021)
Joseph Wallwork, Lucas Mackie, Stephan Kramer, Nicolas Barral, Athanasios Angeloudis, et al.. Goal-Oriented Metric-Based Mesh Adaptive Tidal Farm Modelling. 2021. ⟨hal-03374286⟩
29 Consultations
0 Téléchargements
