Micro Cutting of Ti-6Al-4V Parts Produced by SLM Process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Procedia CIRP Année : 2017
Parts produced by Selective Laser Melting (SLM) presents a roughness due to thickness of fusion layers but also to partially sintered particles stuck to the edge of the parts. In order to ensure a finished product with the dimensional and structural requirements of an industrial part, a post processing by machining is necessary. The aim of the proposed study is to compare the machinability of Ti-6Al-4V obtained by SLM process and that of a cast alloy. Micro-cutting tests are conducted to examine the effect of operating conditions on cutting forces, chip formation and on surface and sub-surface microstructure. .
Le coz (2017).pdf (419.06 Ko) Télécharger le fichier
hal-03375762 , version 1 (13-10-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Gael Le Coz, Marie Fischer, Romain Piquard, A D’acunto, P Laheurte, et al.. Micro Cutting of Ti-6Al-4V Parts Produced by SLM Process. Procedia CIRP, 2017, 58, pp.228-232. ⟨10.1016/j.procir.2017.03.326⟩. ⟨hal-03375762⟩
34 Consultations
48 Téléchargements
