State estimation in nonlinear parametric time dependent systems using Tensor Train - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In the present work we propose a reduced-order method to solve the state estimation problem when nonlinear parametric time-dependent systems are at hand. The method is based on the approximation of the set of system solutions by means of a Tensor Train format. The particular structure of Tensor Train makes it possible to set up both a variational and a sequential method. Several numerical experiments are proposed to assess the behaviour of the method.
art_TTState_final.pdf (1.73 Mo) Télécharger le fichier
hal-03375811 , version 1 (13-10-2021)
hal-03375811 , version 2 (29-06-2022)
hal-03375811 , version 3 (12-07-2022)
  • HAL Id : hal-03375811 , version 2
Damiano Lombardi. State estimation in nonlinear parametric time dependent systems using Tensor Train. 2022. ⟨hal-03375811v2⟩
189 Consultations
177 Téléchargements
