Planar Shape Based Registration for Multi-modal Geometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a global registration algorithm for multi-modal geometric data, typically 3D point clouds and meshes. Existing feature-based methods and recent deep learning based approaches typically rely upon point-to-point matching strategies that often fail to deliver accurate results from defect-laden data. In contrast, we reason at the scale of planar shapes whose detection from input data offers robustness on a range of defects, from noise to outliers through heterogeneous sampling. The detected planar shapes are projected into an accumulation space from which a rotational alignment is operated. A second step then refines the result with a local continuous optimization which also estimates the scale. We demonstrate the robustness and efficacy of our algorithm on challenging real-world data. In particular, we show that our algorithm competes well against state-of-the-art methods, especially on piece-wise planar objects and scenes.
Li_bmvc21.pdf (5.41 Mo) Télécharger le fichier
Li_bmvc2021_supp.pdf (17.01 Mo) Télécharger le fichier
hal-03388316 , version 1 (20-10-2021)
  • HAL Id : hal-03388316 , version 1
Muxingzi Li, Florent Lafarge. Planar Shape Based Registration for Multi-modal Geometry. BMVC 2021 - The British Machine Vision Conference, 2021, virtual, United Kingdom. ⟨hal-03388316⟩
172 Consultations
303 Téléchargements
