Automated performance prediction of microservice applications using simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Microservices transform monolithic applications into simple, scalable, and interacting services. It allows for faster development and fine-grained deployments. However, the cooperation of several services leads to intricate dependencies, hindering the detection of performance bottlenecks. Current microservice performance analysis methods require real deployments, a costly process both in time and resources, while performance prediction through simulation relies on models that are complex to develop and instantiate. In this paper, we propose a microservice performance analysis approach based on simulation. Our contribution first introduces a microservice performance model requiring few instantiation parameters. We then propose a methodology to automatically derive model instantiation values from a single execution trace. We evaluate this methodology on two benchmarks from the literature. Our approach accurately predicts the deployment performance of large-scale microservice applications in various configurations from a single execution trace. This provides valuable insights on the performance of an application prior to its deployment on real platform.
conference_101719.pdf (1.77 Mo) Télécharger le fichier
hal-03389508 , version 1 (21-10-2021)
Clément Courageux-Sudan, Anne-Cécile Orgerie, Martin Quinson. Automated performance prediction of microservice applications using simulation. MASCOTS 2021 - International Symposium on the Modeling, Analysis, and Simulation of Computer and Telecommunication Systems, Nov 2021, virtually, France. pp.1-8, ⟨10.1109/MASCOTS53633.2021.9614260⟩. ⟨hal-03389508⟩
261 Consultations
458 Téléchargements
