Turing instability in an economic–demographic dynamical system may lead to pattern formation on a geographical scale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the Royal Society Interface Année : 2021
Spatial distribution of the human population is distinctly heterogeneous, e.g. showing significant difference in the population density between urban and rural areas. In the historical perspective, i.e. on the timescale of centuries, the emergence of densely populated areas at their present locations is widely believed to be linked to more favourable environmental and climatic conditions. In this paper, we challenge this point of view. We first identify a few areas at different parts of the world where the environmental conditions (quantified by the temperature, precipitation and elevation) show a relatively small variation in space on the scale of thousands of kilometres. We then examine the population distribution across those areas to show that, in spite of the approximate homogeneity of the environment, it exhibits a significant variation revealing a nearly periodic spatial pattern. Based on this apparent disagreement, we hypothesize that there may exist an inherent mechanism that may lead to pattern formation even in a uniform environment. We consider a mathematical model of the coupled demographiceconomic dynamics and show that its spatially uniform, locally stable steady state can give rise to a periodic spatial pattern due to the Turing instability, the spatial scale of the emerging pattern being consistent with observations. Using numerical simulations, we show that, interestingly, the emergence of the Turing patterns may eventually lead to the system collapse.
Interface-21.pdf (3.03 Mo) Télécharger le fichier
hal-03398977 , version 1 (23-10-2021)
Anna Zincenko, Sergei Petrovskii, Vitaly Volpert, Malay Banerjee. Turing instability in an economic–demographic dynamical system may lead to pattern formation on a geographical scale. Journal of the Royal Society Interface, 2021, 18, pp.1-17. ⟨10.1098/rsif.2021.0034⟩. ⟨hal-03398977⟩
38 Consultations
31 Téléchargements
