ISDE : Independence Structure Density Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this paper, we propose ISDE (Independence Structure Density Estimation), an algorithm designed to estimate a multivariate density under Kullback-Leibler loss and the Independence Structure (IS) model. IS tackles the curse of dimensionality by separating features into independent groups. We explain the construction of ISDE and present some experiments to show its performance on synthetic and real-world data. Performance is measured quantitatively by comparing empirical $\log$-likelihood with other density estimation methods and qualitatively by analyzing outputted partitions of variables. We also provide information about complexity and running time.
main.pdf (2.58 Mo) Télécharger le fichier
hal-03401530 , version 1 (25-10-2021)
hal-03401530 , version 2 (12-11-2021)
hal-03401530 , version 3 (17-03-2022)
hal-03401530 , version 4 (05-05-2022)
Louis Pujol. ISDE : Independence Structure Density Estimation. 2022. ⟨hal-03401530v4⟩
179 Consultations
86 Téléchargements
