New interface
Journal articles
A Bayesian tracker for synthesizing mobile robot behaviour from demonstration
Stéphane Magnenat 1 Francis Colas 2
2 LARSEN - Lifelong Autonomy and interaction skills for Robots in a Sensing ENvironment
Inria Nancy - Grand Est, LORIA - AIS - Department of Complex Systems, Artificial Intelligence & Robotics
Abstract : Programming robots often involves expert knowledge in both the robot itself and the task to execute. An alternative to direct programming is for a human to show examples of the task execution and have the robot perform the task based on these examples, in a scheme known as learning or programming from demonstration. We propose and study a generic and simple learning-from-demonstration framework. Our approach is to combine the demonstrated commands according to the similarity between the demonstrated sensory trajectories and the current replay trajectory. This tracking is solely performed based on sensor values and time and completely dispenses with the usually expensive step of precomputing an internal model of the task. We analyse the behaviour of the proposed model in several simulated conditions and test it on two different robotic platforms. We show that it can reproduce different capabilities with a limited number of meta parameters.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03408925
Contributor : Francis Colas Connect in order to contact the contributor
Submitted on : Tuesday, November 2, 2021 - 11:45:59 AM
Last modification on : Friday, July 8, 2022 - 10:04:47 AM
File
bayesian-replay.pdf
Identifiers
Collections
Citation
Stéphane Magnenat, Francis Colas. A Bayesian tracker for synthesizing mobile robot behaviour from demonstration. Autonomous Robots, 2021, ⟨10.1007/s10514-021-10019-4⟩. ⟨hal-03408925v2⟩
Share
Metrics
Record views
150
Files downloads
99
