A new model for the emergence of blood capillary networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks and Heterogeneous Media Année : 2021
We propose a new model for the emergence of blood capillary networks. We assimilate the tissue and extra cellular matrix as a porous medium, using Darcy's law for describing both blood and intersticial fluid flows. Oxygen obeys a convection-diffusionreaction equation describing advection by the blood, diffusion and consumption by the tissue. Discrete agents named capillary elements and modelling groups of endothelial cells are created or deleted according to different rules involving the oxygen concentration gradient, the blood velocity, the sheer stress or the capillary element density. Once created, a capillary element locally enhances the hydraulic conductivity matrix, contributing to a local increase of the blood velocity and oxygen flow. No connectivity between the capillary elements is imposed. The coupling between blood, oxygen flow and capillary elements provides a positive feedback mechanism which triggers the emergence of a network of channels of high hydraulic conductivity which we identify as new blood capillaries. We provide two different, biologically relevant geometrical settings and numerically analyze the influence of each of the capillary creation mechanism in detail. All mechanisms seem to concur towards a harmonious network but the most important ones are those involving oxygen gradient and sheer stress. A detailed discussion of this model with respect to the literature and its potential future developments concludes the paper.
Capillaries_rev_clean.pdf (1.82 Mo) Télécharger le fichier
hal-03409948 , version 1 (12-04-2019)
hal-03409948 , version 2 (02-11-2021)
hal-03409948 , version 3 (04-08-2022)
Pedro Aceves-Sanchez, Benjamin Aymard, Diane Peurichard, Pol Kennel, Anne Lorsignol, et al.. A new model for the emergence of blood capillary networks. Networks and Heterogeneous Media, 2021, 16 (1), pp.91 - 138. ⟨10.3934/nhm.2021001⟩. ⟨hal-03409948v3⟩
171 Consultations
189 Téléchargements
