Analysis of Optical Brain Signals Using Connectivity Graph Networks - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2020
Marco Antonio Pinto-Orellana
  • Function : Author
  • PersonId : 1115811
Hugo L. Hammer
  • Function : Author
  • PersonId : 1115812
Graph network analysis (GNA) showed a remarkable role for understanding brain functions, but its application is mainly narrowed to fMRI research. Connectivity analysis (CA) is introduced as a signal-to-graph mapping in a time-causality framework. In this paper, we investigate the application of GNA/CA in fNIRS. To solve the inherent challenges of using CA, we also propose a novel metric: a maximum cross-lag magnitude (MCLM) that efficiently extracts major causality information. We tested MCLM in four types of cognitive activities (mental arithmetic, motor imagery, word generation, and brain workload) from 55 participants. CA/MCLM showed a compelling modeling capacity and revealed unexpected cross-subject network patterns. We found that motion imagery and mental arithmetic share a background network structure, and that the right prefrontal cortex, in AFp8, is an invariable destination for information flows in every stimuli and participant. Therefore, CA/MCLM-fNIRS showed potential for its use along with fMRI in clinical studies.
497121_1_En_27_Chapter.pdf (953.91 Ko) Télécharger le fichier
Dates and versions
hal-03414723 , version 1 (04-11-2021)
Attribution
Identifiers
Cite
Marco Antonio Pinto-Orellana, Hugo L. Hammer. Analysis of Optical Brain Signals Using Connectivity Graph Networks. 4th International Cross-Domain Conference for Machine Learning and Knowledge Extraction (CD-MAKE), Aug 2020, Dublin, Ireland. pp.485-497, ⟨10.1007/978-3-030-57321-8_27⟩. ⟨hal-03414723⟩
23 View
14 Download
Share
