Property-Based Testing for Parameter Learning of Probabilistic Graphical Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anna Saranti
  • Fonction : Auteur
  • PersonId : 1115834
Behnam Taraghi
  • Fonction : Auteur
  • PersonId : 1067017
Martin Ebner
  • Fonction : Auteur
  • PersonId : 1067019
Code quality is a requirement for successful and sustainable software development. The emergence of Artificial Intelligence and data driven Machine Learning in current applications makes customized solutions for both data as well as code quality a requirement. The diversity and the stochastic nature of Machine Learning algorithms require different test methods, each of which is suitable for a particular method. Conventional unit tests in test-automation environments provide the common, well-studied approach to tackle code quality issues, but Machine Learning applications pose new challenges and have different requirements, mostly as far the numerical computations are concerned. In this research work, a concrete use of property-based testing for quality assurance in the parameter learning algorithm of a probabilistic graphical model is described. The necessity and effectiveness of this method in comparison to unit tests is analyzed with concrete code examples for enhanced retraceability and interpretability, thus highly relevant for what is called explainable AI.
497121_1_En_28_Chapter.pdf (876.55 Ko) Télécharger le fichier
hal-03414744 , version 1 (04-11-2021)
Paternité
Anna Saranti, Behnam Taraghi, Martin Ebner, Andreas Holzinger. Property-Based Testing for Parameter Learning of Probabilistic Graphical Models. 4th International Cross-Domain Conference for Machine Learning and Knowledge Extraction (CD-MAKE), Aug 2020, Dublin, Ireland. pp.499-515, ⟨10.1007/978-3-030-57321-8_28⟩. ⟨hal-03414744⟩
35 Consultations
40 Téléchargements
