A survey on high-dimensional Gaussian process modeling with application to Bayesian optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue (Article De Synthèse) ACM Transactions on Evolutionary Learning and Optimization Année : 2022
Bayesian Optimization, the application of Bayesian function approximation to finding optima of expensive functions, has exploded in popularity in recent years. In particular, much attention has been paid to improving its efficiency on problems with many parameters to optimize. This attention has trickled down to the workhorse of high dimensional BO, high dimensional Gaussian process regression, which is also of independent interest. The great flexibility that the Gaussian process prior implies is a boon when modeling complicated, low dimensional surfaces but simply says too little when dimension grows too large. A variety of structural model assumptions have been tested to tame high dimensions, from variable selection and additive decomposition to low dimensional embeddings and beyond. Most of these approaches in turn require modifications of the acquisition function optimization strategy as well. Here we review the defining structural model assumptions and discuss the benefits and drawbacks of these approaches in practice.
SurveyHighDimBO_hal.pdf (417.54 Ko) Télécharger le fichier
hal-03419959 , version 1 (08-11-2021)
hal-03419959 , version 2 (13-05-2022)
Mickael Binois, Nathan Wycoff. A survey on high-dimensional Gaussian process modeling with application to Bayesian optimization. ACM Transactions on Evolutionary Learning and Optimization, 2022, 2 (2). ⟨hal-03419959v2⟩
161 Consultations
1898 Téléchargements
