Existence and decay of traveling waves for the nonlocal Gross-Pitaevskii equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We consider the nonlocal Gross-Pitaevskii equation that models a Bose gas with general nonlocal interactions between particles in one spatial dimension, with constant density far away. We address the problem of the existence of traveling waves with nonvanishing conditions at infinity, i.e. dark solitons. Under general conditions on the interactions, we prove existence of dark solitons for almost every subsonic speed. Moreover, we show existence in the whole subsonic regime for a family of potentials. The proofs are based on a Mountain Pass argument combined with the so-called "monotonicity trick", as well as on a priori estimates for the Palais-Smale sequences. Finally, we establish properties of the solitons such us exponential decay at infinity and analyticity.
Existence-NGP-final.pdf (614.67 Ko) Télécharger le fichier
hal-03422447 , version 1 (09-11-2021)
hal-03422447 , version 2 (20-04-2022)
  • HAL Id : hal-03422447 , version 1
André de Laire, Salvador López-Martínez. Existence and decay of traveling waves for the nonlocal Gross-Pitaevskii equation. 2021. ⟨hal-03422447v1⟩
90 Consultations
65 Téléchargements
