On the $q$-analogue of Pólya's Theorem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Electronic Journal of Combinatorics Année : 2023
We answer a question posed by Michael Aissen in 1979 about the q-analogue of a classical theorem of George Pólya (1922) on the algebraicity of (generalized) diagonals of bivariate rational power series. In particular, we prove that the answer to Aissen's question, in which he considers $q$ as a variable, is negative in general. Moreover, we show that the answer is positive if and only if $q$ is a root of unity.
BoYu23.pdf (384.56 Ko) Télécharger le fichier
hal-03425997 , version 1 (02-04-2023)
Paternité
  • HAL Id : hal-03425997 , version 1
Alin Bostan, Sergey Yurkevich. On the $q$-analogue of Pólya's Theorem. The Electronic Journal of Combinatorics, 2023. ⟨hal-03425997⟩
46 Consultations
17 Téléchargements
