Effect of Methane, CO 2 , and H 2 S on the Solubility of Methyl and Ethyl Mercaptans in a 25 wt % Methyldiethanolamine Aqueous Solution at 333 and 365 K - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Chemical and Engineering Data Année : 2021
Paper RSH MDEA 25% JCED May 2021 final (2).pdf (1.71 Mo) Télécharger le fichier
hal-03427542 , version 1 (14-11-2021)
Christophe Coquelet, Eric Boonaert, Alain Valtz, Stanley Huang. Effect of Methane, CO 2 , and H 2 S on the Solubility of Methyl and Ethyl Mercaptans in a 25 wt % Methyldiethanolamine Aqueous Solution at 333 and 365 K. Journal of Chemical and Engineering Data, 2021, 66 (11), pp.4000-4017. ⟨10.1021/acs.jced.1c00160⟩. ⟨hal-03427542⟩
64 Consultations
187 Téléchargements
