Feedback Stabilization with Discrete Measurements using Bounds on Fundamental Matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We prove a new robust stabilization theorem for systems with time-varying disturbances and sampled measurements, using novel bounds on fundamental matrices for systems with disturbances. Our main tools use properties of positive systems and Metzler matrices. Our numerical example illustrates an advantage of using our method instead of previous methods.
Mots clés
Automatique
FM_MM_CDC21_TransitionMatrixBounds.pdf (248.51 Ko) Télécharger le fichier
hal-03431458 , version 1 (16-11-2021)
Frederic Mazenc, Michael Malisoff. Feedback Stabilization with Discrete Measurements using Bounds on Fundamental Matrices. IEEE 60th Conference on Decision and Control (CDC 2021), Dec 2021, Austin, United States. ⟨10.1109/cdc45484.2021.9682811⟩. ⟨hal-03431458⟩
30 Consultations
112 Téléchargements
