Deep Video Frame Rate Up-conversion Network using Feature-based Progressive Residue Refinement a - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a deep learning-based network for video frame rate up-conversion (or video frame interpolation). The proposed optical flow-based pipeline employs deep features extracted to learn residue maps for progressively refining the synthesized intermediate frame. We also propose a procedure for finetuning the optical flow estimation module using frame interpolation datasets, which does not require ground truth optical flows. This procedure is effective to obtain interpolation task-oriented optical flows and can be applied to other methods utilizing a deep optical flow estimation module. Experimental results demonstrate that our proposed network performs favorably against state-of-the-art methods both in terms of qualitative and quantitative measures.
VISAPP_2022.pdf (22.21 Mo) Télécharger le fichier
hal-03432380 , version 1 (17-11-2021)
  • HAL Id : hal-03432380 , version 1
Jinglei Shi, Xiaoran Jiang, Christine Guillemot. Deep Video Frame Rate Up-conversion Network using Feature-based Progressive Residue Refinement a. VISAPP 2022 - 17th International Conference on Computer Vision Theory and Applications, Feb 2022, online, France. pp.1-9. ⟨hal-03432380⟩
169 Consultations
71 Téléchargements
