Automatic Questionnaire and Interactive Session Generation from Videos - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
V. C. Skanda
  • Fonction : Auteur
  • PersonId : 1117252
Rachana Jayaram
  • Fonction : Auteur
  • PersonId : 1117253
Viraj C. Bukitagar
  • Fonction : Auteur
  • PersonId : 1117254
N. S. Kumar
  • Fonction : Auteur
  • PersonId : 1117224
In this paper, we present a tool that interleaves lengthy lecture videos with questionnaires at optimal moments. This is done to keep students’ attention by making the video interactive. The student will be presented with MCQ type questions based on the topic covered so far in the video, at regular intervals. The questions are generated based on the transcript of the video lecture using machine learning and natural language processing techniques. In order to have continuity and proper flow of teaching, a LDA-based (Latent Dirichlet Allocation) model has been proposed to insert those generated questions at appropriate points called logical points.
507484_1_En_16_Chapter.pdf (226.63 Ko) Télécharger le fichier
hal-03434799 , version 1 (18-11-2021)
Paternité
V. C. Skanda, Rachana Jayaram, Viraj C. Bukitagar, N. S. Kumar. Automatic Questionnaire and Interactive Session Generation from Videos. 3rd International Conference on Computational Intelligence in Data Science (ICCIDS), Feb 2020, Chennai, India. pp.205-212, ⟨10.1007/978-3-030-63467-4_16⟩. ⟨hal-03434799⟩
30 Consultations
9 Téléchargements
