Disruption of AtHAK/KT/KUP9 enhances plant cesium accumulation under low potassium supply. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physiologia Plantarum Année : 2021
Understanding molecular mechanisms which underlie transport of cesium (Cs+) in plants is important to limit entry of its radioisotopes from contaminated area to the food chain. The potentially toxic element Cs+, which is not involved in any biological process, is chemically closed to the macronutrient potassium (K+). Among the multiple K+ carriers, the high-affinity K+ transporters family HAK/KT/KUP is thought to be relevant in mediating opportunistic Cs+ transport. On the 13 KUP identified in Arabidopsis thaliana, only HAK5, the major contributor to root K+ acquisition under low K+ supply, has been functionally demonstrated to be involved in Cs+ uptake in planta. In the present study, we showed that accumulation of Cs+ increased by up to 30% in two A. thaliana mutant lines lacking KUP9 and grown under low K+ supply. Since further experiments revealed that Cs+ release from contaminated plants to the external medium is proportionally lower in the two kup9 mutant alleles, we proposed that KUP9 disruption could impair Cs+ efflux. By contrast, K+ status in kup9 mutants is not affected suggesting that KUP9 disruption does not alter substantially K+ transport in experimental conditions used. Putative primary role of KUP9 in plants is further discussed.
0000174643_002.PDF (3.66 Mo) Télécharger le fichier
hal-03435786 , version 1 (18-11-2021)
Laure Genies, Ludovic Martin, Satomi Kanno, Serge Chiarenza, Loic Carasco, et al.. Disruption of AtHAK/KT/KUP9 enhances plant cesium accumulation under low potassium supply.. Physiologia Plantarum, 2021, 173 (3), pp.1230-1243. ⟨10.1111/ppl.13518⟩. ⟨hal-03435786⟩
58 Consultations
100 Téléchargements
