Pricing Bermudan options using regression trees/random forests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The value of an American option is the maximized value of the discounted cash flows from the option. At each time step, one needs to compare the immediate exercise value with the continuation value and decide to exercise as soon as the exercise value is strictly greater than the continuation value. We can formulate this problem as a dynamic programming equation, where the main difficulty comes from the computation of the conditional expectations representing the continuation values at each time step. In (Longstaff and Schwartz, 2001), these conditional expectations were estimated using regressions on a finite-dimensional vector space (typically a polynomial basis). In this paper, we follow the same algorithm; only the conditional expectations are estimated using Regression trees or Random forests. We discuss the convergence of the LS algorithm when the standard least squares regression is replaced with regression trees. Finally, we expose some numerical results with regression trees and random forests. The random forest algorithm gives excellent results in high dimensions.
main.pdf (438.42 Ko) Télécharger le fichier
hal-03436046 , version 1 (19-11-2021)
hal-03436046 , version 2 (22-06-2023)
Zineb El Filali Ech-Chafiq, Pierre Henry-Labordere, Jérôme Lelong. Pricing Bermudan options using regression trees/random forests. 2021. ⟨hal-03436046v1⟩
159 Consultations
225 Téléchargements
