Univariate Rational Sums of Squares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revista de la Union Matematica Argentina Année : 2022
Given rational univariate polynomials f and g such that gcd(f, g) and f / gcd(f, g) are relatively prime, we show that g is non-negative on all the real roots of f if and only if g is a sum of squares of rational polynomials modulo f. We complete our study by exhibiting an algorithm that produces a certificate that a polynomial g is non-negative on the real roots of a non-zero polynomial f , when the above assumption is satisfied.
KMS-UMA-revision.pdf (358.26 Ko) Télécharger le fichier
hal-03442193 , version 1 (23-11-2021)
hal-03442193 , version 2 (11-04-2022)
Teresa Krick, Bernard Mourrain, Agnes Szanto. Univariate Rational Sums of Squares. Revista de la Union Matematica Argentina, 2022, 64 (2), pp.215-237. ⟨10.33044/revuma.2904⟩. ⟨hal-03442193v2⟩
108 Consultations
82 Téléchargements
