Univariate Rational Sums of Squares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Given rational univariate polynomials f and g such that gcd(f, g) and f / gcd(f, g) are relatively prime, we show that g is non-negative on all the real roots of f if and only if g is a sum of squares of rational polynomials modulo f. We complete our study by exhibiting an algorithm that produces a certificate that a polynomial g is non-negative on the real roots of a non-zero polynomial f , when the above assumption is satisfied.
main.pdf (214.09 Ko) Télécharger le fichier
hal-03442193 , version 1 (23-11-2021)
hal-03442193 , version 2 (11-04-2022)
Teresa Krick, Bernard Mourrain, Agnes Szanto. Univariate Rational Sums of Squares. 2021. ⟨hal-03442193v1⟩
108 Consultations
82 Téléchargements
