Dependence between Bayesian neural network units
The connection between Bayesian neural networks and Gaussian processes gained a lot of attention in the last few years, with the flagship result that hidden units converge to a Gaussian process limit when the layers width tends to infinity. Underpinning this result is the fact that hidden units become independent in the infinite-width limit. Our aim is to shed some light on hidden units dependence properties in practical finite-width Bayesian neural networks. In addition to theoretical results, we assess empirically the depth and width impacts on hidden units dependence properties.
Machine Learning [stat.ML]
BDL_Dependence_between_units-3.pdf (3.78 Mo)
Télécharger le fichier
main.pdf (3.78 Mo)
