Fault2SHA Central Apennines database and structuring active fault data for seismic hazard assessment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scientific Data Année : 2021
We present a database of field data for active faults in the central Apennines, Italy, including trace, fault and main fault locations with activity and location certainties, and slip-rate, slip-vector and surface geometry data. As advances occur in our capability to create more detailed fault-based hazard models, depending on the availability of primary data and observations, it is desirable that such data can be organized in a way that is easily understood and incorporated into present and future models. The database structure presented herein aims to assist this process. We recommend stating what observations have led to different location and activity certainty and presenting slip-rate data with point location coordinates of where the data were collected with the time periods over which they were calculated. Such data reporting allows more complete uncertainty analyses in hazard and risk modelling. The data and maps are available as kmz, kml, and geopackage files with the data presented in spreadsheet files and the map coordinates as txt files. The files are available at: 10.1594/PANGAEA.922582 .
Tectonique
Scientific Data_Benedetti_2021.pdf (2.65 Mo) Télécharger le fichier
hal-03453649 , version 1 (29-11-2021)
Joanna Faure Walker, Paolo Boncio, Bruno Pace, Gerald Roberts, Lucilla Benedetti, et al.. Fault2SHA Central Apennines database and structuring active fault data for seismic hazard assessment. Scientific Data , 2021, 8 (1), ⟨10.1038/s41597-021-00868-0⟩. ⟨hal-03453649⟩
100 Consultations
110 Téléchargements
