Bird Detection on Transmission Lines Based on DC-YOLO Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to accurately detect the number of birds around the transmission line, promptly drive the birds away to ensure the normal operation of the line, a DC-YOLO model is designed. This model is based on the deep learning target detection algorithm YOLO V3 and proposes two improvements: Replacing the convolutional layer in the original network with dilated convolution to maintain a larger receptive field and higher resolution, improving the model’s accuracy for small targets; The confidence score of the detection frame is updated by calculating the scale factor, and the detection frame with a score lower than the threshold is finally removed. The NMS algorithm is optimized to improve the model’s ability to detect occluded birds. Experimental results show that the DC-YOLO model detection accuracy can reach 86.31%, which can effectively detect birds around transmission lines.
498234_1_En_21_Chapter.pdf (528.32 Ko) Télécharger le fichier
hal-03456984 , version 1 (30-11-2021)
Paternité
Cong Zou, Yong-Quan Liang. Bird Detection on Transmission Lines Based on DC-YOLO Model. 11th International Conference on Intelligent Information Processing (IIP), Jul 2020, Hangzhou, China. pp.222-231, ⟨10.1007/978-3-030-46931-3_21⟩. ⟨hal-03456984⟩
58 Consultations
57 Téléchargements
