Focusing Gentzen's LK proof system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Gentzen's sequent calculi LK and LJ are landmark proof systems. They identify the structural rules of weakening and contraction as notable inference rules, and they allow for an elegant statement and proof of both cut elimination and consistency for classical and intuitionistic logics. Among the undesirable features of those sequent calculi is that their inferences rules are low-level and frequently permute over each other. As a result, large-scale structures within sequent calculus proofs are hard to identify. In this paper, we present a different approach to designing a sequent calculus for classical logic. Starting with Gentzen's LK proof system, we examine the proof search meaning of his inference rules and classify those rules as involving either don't care nondeterminism or don't know nondeterminism. Based on that classification, we design the focused proof system LKF in which inference rules belong to one of two phases of proof construction depending on which flavor of nondeterminism they involve. We then prove that the cut rule and the general form of the initial rule are admissible in LKF. Finally, by showing that the inference rules for LK are all admissible in LKF, we can give a relative completeness proof for LKF provability with respect to LK provability. We shall also apply these properties of the LKF proof system to establish other meta-theoretic properties of classical logic, including Herbrand's theorem.
lkf-2021-03-31.pdf (309.06 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-03457379 , version 1 (30-11-2021)
  • HAL Id : hal-03457379 , version 1
Chuck Liang, Dale Miller. Focusing Gentzen's LK proof system. 2021. ⟨hal-03457379⟩
181 Consultations
503 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
