Deep Reinforcement Learning for Web Crawling
A search engine uses a web crawler to crawl the pages from the world wide web (WWW) and aims to maintain its local cache as fresh as possible. Unfortunately, the rates at which different pages change in WWW are highly nonuniform and also, unknown in many real-life scenarios. In addition, the finite available bandwidth and possible server restrictions on crawling frequency make it very difficult for the crawler to find the optimal scheduling policy that maximises the freshness of the local cache. We model this problem in a multi-armed restless bandits framework, where each arm represents a web page or an aggregate of statistically identical web pages. The objective is to find the scheduling policy that gives the exact indices of the pages to be crawled at a particular instance. We provide an online learning scheme using deep reinforcement learning (DRL) framework which learns the unknown page change dynamics on the fly along with the optimal crawling policy. Finally, we run numerical simulations to compare our approach with state-of-the-art algorithms such as static optimisation and Thompson sampling. We observe better performance for DRL.
