Zero Knowledge Arguments for Verifiable Sampling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2021
César Sabater
Jan Ramon
In privacy-preserving machine learning, it is less obvious to verify correct behavior of participants because they are not supposed to reveal their inputs in cleartext to other participants. It is hence important to make federated machine learning robust against data poisoning and related attacks. While input data can be related to a distributed ledger (blockchain), a less studied input is formed by the random sampling parties perform. In this paper, we describe strategies based on zero knowledge proofs to allow parties to prove they perform sampling (and other computations) correctly. We sketch a number of alternative ways to implement our idea and provide some preliminary experimental results.
main.pdf (179.05 Ko) Télécharger le fichier
hal-03464840 , version 1 (03-12-2021)
  • HAL Id : hal-03464840 , version 1
César Sabater, Jan Ramon. Zero Knowledge Arguments for Verifiable Sampling. NeurIPS 2021 Workshop Privacy in Machine Learning, Dec 2021, Sydney (Virtual), Australia. . ⟨hal-03464840⟩
51 Consultations
119 Téléchargements
