Phase Transition of the 3-Majority Dynamics with Uniform Communication Noise - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2021
Communication noise is a common feature in several real-world scenarios where systems of agents need to communicate in order to pursue some collective task. In particular, many biologically inspired systems that try to achieve agreements on some opinion must implement resilient dynamics that are not strongly affected by noisy communications. In this work, we study the popular 3-Majority dynamics, an opinion dynamics which has been proved to be an efficient protocol for the majority consensus problem, in which we introduce a simple feature of uniform communication noise, following (d'Amore et al. 2020). We prove that in the fully connected communication network of n agents and in the binary opinion case, the process induced by the 3-Majority dynamics exhibits a phase transition. For a noise probability $p < 1/3$, the dynamics reaches in logarithmic time an almost-consensus metastable phase which lasts for a polynomial number of rounds with high probability. Furthermore, departing from previous analyses, we further characterize this phase by showing that there exists an attractive equilibrium value $s_{\text{eq}} \in [n]$ for the bias of the system, i.e. the difference between the majority community size and the minority one. Moreover, the agreement opinion turns out to be the initial majority one if the bias towards it is of magnitude $\Omega(\sqrt{n\log n})$ in the initial configuration. If, instead, $p > 1/3$, no form of consensus is possible, and any information regarding the initial majority opinion is lost in logarithmic time with high probability. Despite more communications per-round are allowed, the 3-Majority dynamics surprisingly turns out to be less resilient to noise than the Undecided-State dynamics (d'Amore et al. 2020), whose noise threshold value is $p = 1/2$.
3maj.pdf (295.2 Ko) Télécharger le fichier
Dates and versions
hal-03467403 , version 1 (06-12-2021)
hal-03467403 , version 2 (09-12-2021)
Identifiers
Cite
Francesco d'Amore, Isabella Ziccardi. Phase Transition of the 3-Majority Dynamics with Uniform Communication Noise. SIROCCO 2022 - Structural information and communication complexity, Jun 2022, Paderborn, Germany. ⟨10.1007/978-3-031-09993-9_6⟩. ⟨hal-03467403v2⟩
82 View
78 Download
Share
