Representations of Deligne-Mostow lattices into PGL(3, C). Part II - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We complete the classification of type preserving representations of Deligne-Mostow lattices with 3-fold symmetry into PGL(3, C) started in [FPUP21a]. In particular, we show local rigidity for all the representations where the generators we chose are of the same type as the generators of the Deligne-Mostow lattices. We use formal computations in SAGE and MAPLE to obtain the results. The code files are available on GitHub ([FPUP21b]).
DMrepresentationsII.pdf (312.5 Ko) Télécharger le fichier
hal-03468849 , version 1 (07-12-2021)
  • HAL Id : hal-03468849 , version 1
Elisha Falbel, Irene Pasquinelli, Alejandro Ucan-Puc. Representations of Deligne-Mostow lattices into PGL(3, C). Part II. 2021. ⟨hal-03468849⟩
30 Consultations
16 Téléchargements
