T-coercivity for the homogenization of sign-changing coefficients scalar problems with extreme contrasts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Reports Année : 2022
We study the homogenization of a diffusion-type problem, for sign-changing conductivities with extreme contrasts. The weak limit, which is proved to be the same as in the elliptic case of positive conductivities, has an explicit dependence on the conductivities.
Bun-Ram-Tim-ExtremeContrasts.pdf (383.37 Ko) Télécharger le fichier
hal-03481978 , version 1 (15-12-2021)
hal-03481978 , version 2 (25-05-2022)
  • HAL Id : hal-03481978 , version 1
Karim Ramdani, Renata Bunoiu, Claudia Timofte. T-coercivity for the homogenization of sign-changing coefficients scalar problems with extreme contrasts. Mathematical Reports, In press, Marius Tucsnak 60th Anniversary Volume, 24(74) (1-2). ⟨hal-03481978v1⟩
196 Consultations
93 Téléchargements
