Cost and Quality in Crowdsourcing Workflows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Crowdsourcing platforms provide tools to replicate and distribute micro tasks (simple, independent work units) to crowds and assemble results. However, real-life problems are often complex: they require to collect, organize or transform data, with quality and costs constraints. This work considers dynamic realization policies for complex crowdsourcing tasks. Workflows provide ways to organize a complex task in phases and guide its realization. The challenge is then to deploy a workflow on a crowd, i.e., allocate workers to phases so that the overall workflow terminates, with good accuracy of results and at a reasonable cost. Standard "static" allocation of work in crowdsourcing affects a fixed number of workers per micro-task to realize and aggregates the results. We define new dynamic worker allocation techniques that consider progress in a workflow, quality of synthesized data, and remaining budget. Evaluation on a benchmark shows that dynamic approaches outperform static ones in terms of cost and accuracy.
PN-workflows.pdf (890.92 Ko) Télécharger le fichier
hal-03482424 , version 1 (15-12-2021)
Loïc Hélouët, Zoltan Miklos, Rituraj Singh. Cost and Quality in Crowdsourcing Workflows. PETRI NETS 2021 - 42nd International Conference on Applications and Theory of Petri Nets and Concurrency, Jun 2021, Paris, France. pp.33-54, ⟨10.1007/978-3-030-76983-3_3⟩. ⟨hal-03482424⟩
18 Consultations
94 Téléchargements
