Reducing differences in earthquake activity rate estimates across borders in Europe - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2021
Earthquake activity rates estimated in cross-border regions can differ between countries. This study aims at answering the following question: how much of the difference in the annual seismicity rates in the Alps cross-border region is due to different methodologies used to compute historical earthquake magnitudes? To answer this question, we built two historical (pre-1980) parametric earthquake catalogues for this region considering a common post-1980 earthquake catalogue. To focus on methodological differences, it was necessary to first build a common macroseismic and instrumental magnitude dataset to calibrate the two methodologies considered, namely Boxer and QUake-MD. We then applied the two methodologies to the same macroseismic dataset to build the two new historical (pre-1980) parametric earthquake catalogues. Finally, we computed earthquake rates for the two catalogues and found them to be statistically similar. This exercise underlines that reducing existing differences in seismic activity rate estimates across border regions will necessarily require a common definition of instrumental magnitudes and a common macroseismic dataset.
Poster_BoxerQUakeMD.pdf (747.16 Ko) Télécharger le fichier
hal-03482598 , version 1 (16-12-2021)
  • HAL Id : hal-03482598 , version 1
Ludmila Provost, Andrea Antonucci, Andrea Rovida, Oona Scotti. Reducing differences in earthquake activity rate estimates across borders in Europe. 5èmes Rencontres Scientifiques et Techniques Résif, Nov 2021, Obernai (67210), France. ⟨hal-03482598⟩
22 Consultations
48 Téléchargements
