SARS-CoV-2 mechanistic correlates of protection: insight from modelling response to vaccines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The definition of correlates of protection is critical for the development of next generation SARS-CoV-2 vaccine platforms. Here, we propose a new framework for identifying mechanistic correlates of protection based on mathematical modelling of viral dynamics and data mining of immunological markers. The application to three different studies in non-human primates evaluating SARS-CoV-2 vaccines based on CD40-targeting, two-component spike nanoparticle and mRNA 1273 identifies and quantifies two main mechanisms that are a decrease of rate of cell infection and an increase in clearance of infected cells. Inhibition of RBD binding to ACE2 appears to be a robust mechanistic correlate of protection across the three vaccine platforms although not capturing the whole biological vaccine effect. The model shows that RBD/ACE2 binding inhibition represents a strong mechanism of protection which required significant reduction in blocking potency to effectively compromise the control of viral replication.
20211024_Draft_mCoP_Medarxiv.pdf (1.57 Mo) Télécharger le fichier
20211024_SI_mCoP_Medarxiv.pdf (3.11 Mo) Télécharger le fichier
hal-03482728 , version 1 (16-12-2021)
hal-03482728 , version 2 (18-01-2023)
Paternité
Marie Alexandre, Romain Marlin, Mélanie Prague, Séverin Coleon, Nidhal Kahlaoui, et al.. SARS-CoV-2 mechanistic correlates of protection: insight from modelling response to vaccines. 2021. ⟨hal-03482728v1⟩
172 Consultations
123 Téléchargements
