Handling Correlations in Random Forests: which Impacts on Variable Importance and Model Interpretability? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The present manuscript tackles the issues of model interpretability and variable importance in random forests, in the presence of correlated input variables. Variable importance criteria based on random permutations are known to be sensitive when input variables are correlated, and may lead for instance to unreliability in the importance ranking. In order to overcome some of the problems raised by correlation, an original variable importance measure is introduced. The proposed measure builds upon an algorithm which clusters the input variables based on their correlations, and summarises each such cluster by a synthetic variable. The effectiveness of the proposed criterion is illustrated through simulations in a regression context, and compared with several existing variable importance measures.
SMDA_ESANN2021_Corrected (2).pdf (274.19 Ko) Télécharger le fichier
hal-03483385 , version 1 (16-12-2021)
  • HAL Id : hal-03483385 , version 1
Marie Chavent, Jerome Lacaille, Alex Mourer, Madalina Olteanu. Handling Correlations in Random Forests: which Impacts on Variable Importance and Model Interpretability?. ESANN 2021 - European Symposium on Artificial Neural Networks, Computational Intelligence and Machine Learning, Oct 2021, Bruges, Belgium. ⟨hal-03483385⟩
167 Consultations
1208 Téléchargements
