Probabilistic representations of fragmentation equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Probability Surveys Année : 2023
In this survey article, we present various probabilistic representations of the fragmentation equation, and show how they are related. We focus on the stochastic process which represents the evolution of the mass of a typical particle subjected to a fragmentation process. These probabilistic representations range from Markov chains to Stochastic Differential Equations with jumps, and we consider how they are interrelated. In particular, we show how these representations leads to easy numerical simulations.
fragmentation_equation-FV.pdf (1.13 Mo) Télécharger le fichier
hal-03483448 , version 1 (16-12-2021)
hal-03483448 , version 2 (25-11-2022)
hal-03483448 , version 3 (03-03-2023)
hal-03483448 , version 4 (13-03-2023)
  • HAL Id : hal-03483448 , version 3
Madalina Deaconu, Antoine Lejay. Probabilistic representations of fragmentation equations. Probability Surveys, In press. ⟨hal-03483448v3⟩
212 Consultations
171 Téléchargements
