An Eulerian finite-volume approach of fluid-structure interaction problems on quadtree meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2022
Une approche volume fini eulérienne pour des problèmes d'interaction fluide-structure sur maillages quadtree
A quadtree-based fully Eulerian finite volume approach for the simulation of fluid-structure interaction problems is presented. Both fluid and structure phases are solved monolithically on the whole computational domain. The discretization stencils are limited to the first layer of neighbors thus enhancing the efficiency of the parallel computations while limiting the numerical order of the finite volume discretizations that can be reached. The behavior of hyperelastic structures is described with the non-linear Mooney-Rivlin model. The simulation of several two dimensional test cases is performed on uniform and quadtree grids and results are compared with the literature. To illustrate the versatility of the numerical model presented, a biomedical application, the axisymmetric simulation of a blood flow in a cardiac pump, is presented.
Article_HAL_Inria.pdf (19.75 Mo) Télécharger le fichier
hal-03485251 , version 1 (17-12-2021)
hal-03485251 , version 2 (10-10-2022)
  • HAL Id : hal-03485251 , version 1
Michel Bergmann, Antoine Fondanèche, Angelo Iollo. An Eulerian finite-volume approach of fluid-structure interaction problems on quadtree meshes. Journal of Computational Physics, In press. ⟨hal-03485251v1⟩
44 Consultations
59 Téléchargements
