Low-cost Multispectral Scene Analysis with Modality Distillation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Despite its robust performance under various illumination conditions, multispectral scene analysis has not been widely deployed due to two strong practical limitations: 1) thermal cameras, especially high-resolution ones are much more expensive than conventional visible cameras; 2) the most commonly adopted multispectral architectures, twostream neural networks, nearly double the inference time of a regular mono-spectral model which makes them impractical in embedded environments. In this work, we aim to tackle these two limitations by proposing a novel knowledge distillation framework named Modality Distillation (MD). The proposed framework distils the knowledge from a high thermal resolution two-stream network with featurelevel fusion to a low thermal resolution one-stream network with image-level fusion. We show on different multispectral scene analysis benchmarks that our method can effectively allow the use of low-resolution thermal sensors with more compact one-stream networks.
WACV2022_MD.pdf (7.13 Mo) Télécharger le fichier
hal-03491950 , version 1 (18-12-2021)
  • HAL Id : hal-03491950 , version 1
Heng Zhang, Elisa Fromont, Sébastien Lefèvre, Bruno Avignon. Low-cost Multispectral Scene Analysis with Modality Distillation. WACV 2022 - IEEE Winter Conference on Applications of Computer Vision, Jan 2022, Waikoloa /Virtual, United States. pp.1-10. ⟨hal-03491950⟩
36 Consultations
43 Téléchargements
