Approximate Computing Techniques: From Component- to Application-Level - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2022
Approximate Computing (AxC) is a promising technique for reducing area and power consumption as well as for improving performance of a computing system. However, AxC is still in its infancy since there is a lack of methodologies and automated tools for the entire design and manufacturing flow. The book will present different state-of-the-art AxC techniques, and how they integrate into the design flow. It also describes real AxC applications spanning from mobile to high- performance computing and safety-critical applications. This book can therefore serve an important reference for researchers, students and engineers interested in the field of Approximate Computing.
hal-03494868 , version 1 (20-12-2021)
Alberto Bosio, Daniel Menard, Olivier Sentieys. Approximate Computing Techniques: From Component- to Application-Level. Springer, 2022, 978-3-030-94705-7. ⟨10.1007/978-3-030-94705-7⟩. ⟨hal-03494868⟩
171 Consultations
0 Téléchargements
