Fixed Point Strategies in Data Science - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2021
The goal of this paper is to promote the use of fixed point strategies in data science by showing that they provide a simplifying and unifying framework to model, analyze, and solve a great variety of problems. They are seen to constitute a natural environment to explain the behavior of advanced convex optimization methods as well as of recent nonlinear methods in data science which are formulated in terms of paradigms that go beyond minimization concepts and involve constructs such as Nash equilibria or monotone inclusions. We review the pertinent tools of fixed point theory and describe the main state-of-the-art algorithms for provenly convergent fixed point construction. We also incorporate additional ingredients such as stochasticity, block-implementations, and non-Euclidean metrics, which provide further enhancements. Applications to signal and image processing, machine learning, statistics, neural networks, and inverse problems are discussed.
sp14.pdf (780.92 Ko) Télécharger le fichier
hal-03495546 , version 1 (04-01-2022)
Patrick Combettes, Jean-Christophe Pesquet. Fixed Point Strategies in Data Science. IEEE Transactions on Signal Processing, 2021, 69, pp.3878-3905. ⟨10.1109/TSP.2021.3069677⟩. ⟨hal-03495546⟩
128 Consultations
114 Téléchargements
