Relational concept analysis for circular link key extraction
A link key extraction procedure in case of circular dependencies is presented. It uses relational concept analysis and extends the procedure of Deliverable 1.1. This leads to investigate more closely the semantics of relational concept analysis which is given in terms of fixed points. Extracting all fixed points may offer more link key candidates to consider.
