Hyperbolic balance laws: residual distribution, local and global fluxes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
This review paper describes a class of scheme named "residual distribution schemes" or "fluctuation splitting schemes". They are a generalization of Roe's numerical flux [61] in fluctuation form. The so-called multidimensional fluctuation schemes have historically first been developed for steady homogeneous hyperbolic systems. Their application to unsteady problems and conservation laws has been really understood only relatively recently. This understanding has allowed to make of the residual distribution framework a powerful playground to develop numerical discretizations embedding some prescribed constraints. This paper describes in some detail these techniques, with several examples, ranging from the compressible Euler equations to the Shallow Water equations.
2109.08491.pdf (6.2 Mo) Télécharger le fichier
hal-03508452 , version 1 (03-01-2022)
hal-03508452 , version 2 (24-01-2022)
Remi Abgrall, Mario Ricchiuto. Hyperbolic balance laws: residual distribution, local and global fluxes. 2021. ⟨hal-03508452v2⟩
30 Consultations
33 Téléchargements
